looking at 140 or 140t
发表于 2021-8-31 22:20:25 | 显示全部楼层 |阅读模式
what are the differences? I'm new and would like to start welding on simple small parts.. namely SS pipes and aluminum pipes.. anyone had good luck using the spoolgun?
Reply:I have the power mig 140c and it works great with the spool gun. I have welded a canoe, john jet boat,to square aluminum tubing for a shade umbrella. After welding the back fins on my john boat a coupleweeks later I stupidly backed-up in to something bent one of the fins straight up. I heated it up and bentit back down and it did not break the weld. Still ran a new bead just in case, for strength.The Power Mig 140's are pretty strong for 120v welders.
Reply:The 140C would be continuous voltage adjustment, the 140T would be tapped voltage adjustment.
Reply:Thanks, I forgot to mention that.
Reply:I also have a 140c and the spoolgun, dont use the spoolgun much, but it does do a good job on thinner al. My PM has good arc and a nice sweet spot and i couldnt be happyier from a 120v machine. I use mine on a regular basis and it always takes what i throw at it. Although now it might not see as much use since i just got a nice PM 255!Miller Dynasty 300dxSpeedglas 9002XMiller Spectrum 375 XtremeLincoln PowerMig 255xtLincoln PowerMig 140cMilwuakee Portaband
Reply:Don't waste your money on a 140.Get the 180. You will NEVER regret buying it.The saying goes: "Get a 140 and buy twice. Get a 180 and buy once..."
Reply:You are correct. I ended up with a Power Mig 216, yes not a 255 as two post earlier ,youlucky dog you! But I won't give my 140c up yet. Just got a call to weld a hole in a John boat. They only have 120V and I do not want to drag my 216 over there. Still wonderingwhy he won't bring it to me though. (lazy mabey, I do not know) but they pay I weld.
Reply:As you have just found out, there are situations where the 110V machines are key, if you have thin material and only 110V power, you just cant beat a small machine. Now you could drag a generator and load up you new 200# machine and head over there, but it is so much easier to throw the 50# 140 in the back seat and hit the road. I will not be getting rid of my 140c thats for sure, yes i do have the 255xt, but there will always be a place for the 140, just my opinion.Miller Dynasty 300dxSpeedglas 9002XMiller Spectrum 375 XtremeLincoln PowerMig 255xtLincoln PowerMig 140cMilwuakee Portaband
GMT+8, 2026-1-1 15:12 , Processed in 0.106643 second(s), 18 queries .
