New SA200
发表于 2021-8-31 22:20:25 | 显示全部楼层 |阅读模式
Hello, I recently purchased a SA200 ser# D19536 I believe it to be a 1941 model, unit runs great and welds better than anything I have ever used, but it will not idle up or down on it's own and I am unable to locate any manuals for the welder, so any help or avice would be great. THANKS
Reply:If you havent tried Lincoln Electric's web site, you might start there.  Check under quick links, operators manuals, and then obsolete manuals.  Not sure if they got one for your machine, might be worth a try.  Good luck.A few of my toys !LinuxMintManjaroMiller Roughneck 2E Lincoln WeldPak 100HTP MTS 160 Chicago Electric 80amp Inverter   Victor O/A
Reply:You may also need the code number off the machine to get the correct manual.A few of my toys !LinuxMintManjaroMiller Roughneck 2E Lincoln WeldPak 100HTP MTS 160 Chicago Electric 80amp Inverter   Victor O/A
Reply:Thanks, I tried the Lincoln web site and downloaded a manual, but it's just for the welding unit and not the engine, which is  hercules, and I will call bills, thisweek to see if te have any tin for the unit, I think I will convert the vaccum idle contol to a new electric unit to slove the idle problem.
Reply:For Hercules engines you might want to look at this site:http://www.herculesengines.com/hercu...iterature.htmlGordie -- "I believe you understand what you think I said, but I'm not sure you realize that what you heard is not what I meant."
GMT+8, 2026-1-1 15:14 , Processed in 0.104841 second(s), 18 queries .
