115v fuse, sa200
发表于 2021-8-31 22:20:24 | 显示全部楼层 |阅读模式
Has anyone put a circuit breaker in to replace the glass fuse assy. I can get 12v 15 amp manual reset but don't know if it will work due to voltage. My chop saw blows the fuse if I press hard, it draws 14 amps. The saw is an ac/dc machine.Last edited by ecclectic iron; 09-11-2009 at 03:31 PM.Reason: more specific
Reply:I wouldn't use a 12v breaker on 120 -- not capable of interrupting the  current at that voltage. Try http://www.mouser.com/Circuit-Protec...reaker&FS=Truefred-- fredLincoln 180C MIG
GMT+8, 2026-1-1 15:13 , Processed in 0.101677 second(s), 18 queries .
