Magnetic tig torch holder
发表于 2021-8-31 22:20:18 | 显示全部楼层 |阅读模式
I've had a strange 7/16" Proto combination wrench for about 30 years and never found a use for it, so thought I'd make a tig torch holder out of it. This wrench is an original proto wrench and was made this way. Anyone have a thought as to what it was made for? I have two of them. Attached Images
Reply:Starter wrench?
Reply:Google the Proto part number.
Reply:I would say for the alternator on a Saab if it was 13 MM
Reply:I googled the part # 1214 and nothing resembling the wrench came up. the part # brought up a 7/16 combination wrench.
Reply:Are you sure it came from Proto like that? I see nothing online showing that part number and a bent wrench.GravelThe difference between theory and practice is that in theory there is no difference.
Reply:Originally Posted by 7A749Either way, very cool use for it.
Reply:Originally Posted by Willie BI would say for the alternator on a Saab if it was 13 MM
Reply:Originally Posted by Willie BWhere did that come from? I didn't say that.
Reply:I've bent, cut, welded a number of wrenches/sockets for special applications.... not uncommon to avoid buying specialty OEM toolsSent from my SM-G900V using TapatalkGlenMiller Dynasty 200DX - Millermatic 350P - Hypertherm Powermax 45Want to sell!! - Hobart Handler 150
Reply:I really think they came from Proto bent like they are. The bends are pretty tight and there is no indication of clamping or heating to make the bends.
Reply:How do you like that everlast?
Reply:Originally Posted by helicoilHow do you like that everlast?
Reply:Originally Posted by SandyThere's two of you Willie ??
GMT+8, 2026-1-1 17:21 , Processed in 0.144282 second(s), 18 queries .
