If I'm putting something together, and I grind down the bead and into the metal, then lay in another bead so it'll be halfway into the metal. Then grind off the excess bead on top so it'd look like a smooth transition. Kind of like this, but on the welding table welds or welding cart welds. Diablo makes these flap discs that are edged so you can grind into corners
Reply:For what your doing it will be fine.www.georgesplasmacuttershop.comPlasma Cutter and Welder Sales and Repairs--Ebay storeTec.Mo. Dealer Consumables for the PT and IPT torch's
Reply:should be fine on a welding table or a welding cart.Millermatic 211Miller Syncrowave 350lx with cooler and tigrunner Thermal Dynamics cutmaster 811955 National Cylinder Gas O/A setup with original patina |
