4943
发表于 2021-8-31 22:20:13 | 显示全部楼层 |阅读模式
Hobart lists 4943 TIG rod. They say my nearest dealer is Airgas. Locally, or online Airgas has never heard of the stuff. Does anyone have a good source. I would start with 10 lbs to see how it works, 1/16?
Reply:I would go onl line with e bay. Nobody seems to stock it, and its been out a while now.I hate being bi-polar it's awsomeMy Heroes Have Always Been Cowboys
Reply:Originally Posted by 7A749Yup. Not a lot of places carrying it, and the ones that do seem to be overpriced.You can get it from my LWS. They can drop ship it directly to you.Purity Cylinder Gasses. Lansing, MI 48906. 517-321-9555Ask for Jim Maguire. He's the store manager and can do it over the phone with a credit card.Just a thought if you can't get it locally.
Reply:I get mine from Sims in SoCal. B_C gets his from Matheson in NorCal I believe. Yes is is a buck or 2 per lb higher in price than it should be. Hopefully the prices will fall as it becomes more common.Weld like a "WELDOR", not a wel-"DERR" MillerDynasty700DX,Dynasty350DX4ea,Dynasty200DX,Li  ncolnSW200-2ea.,MillerMatic350P,MillerMatic200w/spoolgun,MKCobraMig260,Lincoln SP-170T,PlasmaCam/Hypertherm1250,HFProTig2ea,MigMax1ea.
Reply:So I've been wanting to try this too. I just called up and down the coast in Cali, no one has the vaguest idea. I called Hobart and they said Cali has some (don't know where, the phone  number in Sac he gave me had no idea.) and said Ohio has 600 lbs, but again, no where to be seen.I finally called the guys in Indiana that sold me my Dynasty and he actually took my order. http://www.weldingsuppliesfromioc.com/  866-854-7380 So he said it would take a few days to get in, but a 10 lb box cost me $60 for .125 and for the .062 it was $65 and free shipping.So I ordered a box of each.Regards,RobGreat Basin WeldingInstagramBlue weldersRed weldersMy luscious Table DIY TIG Torch cooler
Reply:As 4943 becomes more popular so will it's availability, use it and fall in love like all of us
Reply:Just now
Reply:Hobart just bought Maxal recently so it's not a surprise the people at air gas don't know about it.Torchmate 2x2 CNC with Flashcut CNC controlsHypertherm Powermax45 Esab ET220i Razorweld 195 MigRazorweld 200ac/dc TigTormach 770, Tormach xstechRazorweld, Vipercut/Vipermig, SSC Foot Pedal Dealer
Reply:Mine is on the UPS truck as I typeRegards,RobGreat Basin WeldingInstagramBlue weldersRed weldersMy luscious Table DIY TIG Torch cooler
Reply:Originally Posted by GambleHobart just bought Maxal recently so it's not a surprise the people at air gas don't know about it.
Reply:Ha you would think, but I've seen things move pretty slow at my local air gas. They still don't even know who lincoln or miller are yet hahaTorchmate 2x2 CNC with Flashcut CNC controlsHypertherm Powermax45 Esab ET220i Razorweld 195 MigRazorweld 200ac/dc TigTormach 770, Tormach xstechRazorweld, Vipercut/Vipermig, SSC Foot Pedal Dealer
Reply:"anyone ever see one of those fancy new fangled synchrowaves run yet?"-overheard at airgas last week
Reply:Airgas actually found the stuff and shipped it to my house. Unfortunately the two diameters came from two places, so I got hosed on shipping, which was not included. But they did it. Service is very store dependent.I would use Indiana after reading this thread again.
Reply:Pretty happy with the results. 3/32" dia. 4943 on .035" wall 6061 tube. Fast and free flowing. Weld like a "WELDOR", not a wel-"DERR" MillerDynasty700DX,Dynasty350DX4ea,Dynasty200DX,Li  ncolnSW200-2ea.,MillerMatic350P,MillerMatic200w/spoolgun,MKCobraMig260,Lincoln SP-170T,PlasmaCam/Hypertherm1250,HFProTig2ea,MigMax1ea.
Reply:Beautiful!
Reply:nice tigging on small tube.i.u.o.e. # 15queens, ny and sunny fla
Reply:Pretty weld.Waiting for some 1/8" 4943 to weld the cooler tank up. Im using 1/8" diamond plate. 3/32 is hard to feed fast enough.
Reply:Originally Posted by atgPretty weld.Waiting for some 1/8" 4943 to weld the cooler tank up. Im using 1/8" diamond plate. 3/32 is hard to feed fast enough.
Reply:I can get tiny little beads on the diamond plate with 3/32 250Hz but didnt know if I should be trying for a fatter bead
Reply:Originally Posted by atgI can get tiny little beads on the diamond plate with 3/32 250Hz but didnt know if I should be trying for a fatter bead
Reply:Originally Posted by shovelonPretty happy with the results. 3/32" dia. 4943 on .035" wall 6061 tube. Fast and free flowing.
Reply:Originally Posted by MinnesotaDaveHave to say...I'm a little jealous
Reply:Originally Posted by shovelonDon't be. The rotary table did all the work. I do like this stuff though.
Reply:Back on 5/31 Kevin Morin started a thread on this alloy, very interesting.  If you are in Northwestern New Jersey and have a need for this stuff, County Welding in Wharton NJ stocks this (973-366-2320) I have purchased it from them @ $7.92 for 1/16 & $7.18 for 3/32 per lb.  Hope this helps.  Best regards,  BobOriginally Posted by shovelonYeah it's hard to tell without seeing it. Does 250Hz stabilize the arc for you?  I would limit wetting and a wider bead I think. Highest I can stand is 140Hz.
Reply:4943 3/32" 1/8" 3003 diamond plate 1" strips open corner
Reply:Originally Posted by atg4943 3/32" 1/8" 3003 diamond plate 1" strips open corner
Reply:Yes 100%. At least thats what the dial on the mixer says. I always have both cylinders turned on so there could be some He in there. Shouldnt be much though. Honestly I never read the manual but the sticker says to turn He cylinder on, then Ar, and so I always do that even when on Ar100%. I just dont want to break whatever mechanism is in there.Last edited by atg; 08-21-2014 at 02:29 PM.
Reply:There are a couple of tungsten gags on there also in case you were thinking it was helium soot.Last edited by atg; 08-21-2014 at 02:29 PM.
Reply:Ahh I love 4943...
GMT+8, 2026-1-1 17:11 , Processed in 0.359030 second(s), 18 queries .
