Band Saw Speed Reduction
发表于 2021-8-31 22:20:06 | 显示全部楼层 |阅读模式
A couple of recent postings have inquired about how to slow a wood working vertical band saw down to suitable metal cutting speeds.  Here are couple of articles that might be of interest for those wishing to go with the jack shaft method.http://books.google.com/books?id=T9k...per%22&f=falsehttp://books.google.com/books?id=vyo...%20saw&f=falseHope this is helpful.RogerOld, Tired, and GRUMPYSalesman will call, Batteries not included, Assembly is required, and FREE ADVICE IS WORTH EXACTLY WHAT YOU PAY FOR IT!Dial Arc 250HFThunderbolt 225 AC/DCAssorted A/O torches
Reply:Thank you.  Very interesting and helpful.TA Arcmaster 300CM3XMT 304S22P12 suitcase feederX-Treme 12VSOptima pulserTA161SMaxstar 150STLHypertherm PM45OP setupStihl 020AVP, 039, 066 Magnum
Reply:Would a 3 phase motor and a vfd work?
Reply:Originally Posted by RyanjaxWould a 3 phase motor and a vfd work?
Reply:VFD's usually push a high frequency voltage through the windings at low motor speeds to prevent overheating.  VFD's can run a motor all of the way down to its stall rating without overheating the motor.
Reply:Originally Posted by 76GMC1500VFD's usually push a high frequency voltage through the windings at low motor speeds to prevent overheating.  VFD's can run a motor all of the way down to its stall rating without overheating the motor.
Reply:Thanks for posting this information.
Reply:Originally Posted by WyoRoyMaybe on higher priced inverter rated motors. A standard motor is usually fan cooled internally and reducing the speed also reduces the fan speed resulting in higher motor temperature.
Reply:Convert it with a treadmill dc motor very easy google it.V
Reply:Originally Posted by VinnieConvert it with a treadmill dc motor very easy google it.V
Reply:I used the gear box off my old front-tine tiller. It has the proper gear reduction and is definitely heavy duty enough for the load... and it was free!
GMT+8, 2026-1-1 17:08 , Processed in 0.089257 second(s), 18 queries .
