SA-200 Crankcase Vent Hose
发表于 2021-8-31 22:20:05 | 显示全部楼层 |阅读模式
What do you guys use on your Continental F162/163 engines for the crankcase ventilation hose....?
Reply:Nothing.If you have excessive blow-by that's resulting in oiling down the unit around the stock vent tube, it's time for an overhaul.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:It doesn't (didn't) have any blowby.  I am in the restoration process right now.  When looking at the P-23 Lincoln parts doc., I noticed that they show the valve chamber cover w/crankcase vent hose as 1 item.  My hose will probably be OK after I clean it up and give it a little rehab.  I was just looking for one just in case.  This project is really coming along and I will post before, during, and after pics.  I sure have learned a lot, which was part of the plan.  All you guys here have been a world of knowledge.  After I get the '67 back to "stock" condition, I plan to score another machine and make a "hot rod" project.  My "little praline" already advised me to start looking for a place to live, if I didn't give her her side of the garage back.  She doesn't understand.....................
Reply:wouldnt regular automotive emissions hose work?bobs77vet/37ford4drEastwood digital TIG200HH190Lincoln Invertec 155sLincoln weldpak 100sears/craftsman (lincoln) 50a 240v buzz boxO/A rig Harris gaugesnexion cut 50 dxchicago electric (HF) 240v spot welder
GMT+8, 2026-1-1 16:59 , Processed in 0.174407 second(s), 18 queries .
