SA200 oil drain valve
发表于 2021-8-31 22:20:05 | 显示全部楼层 |阅读模式
Well I just got my fumoto oil drain valve for my 1973 sa200 today it has a f-163 motor and the oil drain valve part num. is fg-7bn the thread size is 22mm 1.5 for anyone that wants one other than a fumoto I did notice however that it doesn't thread all the way in to the gasket but it doesn't leak so I'm not gonna worry about it at this point. It was a nightmare tryin to find out what one would work for this application. So as long as its not leaking I'm happy hope this helps.1973 Lincoln SA 200, Already replaced shunt coils, Idle board (SOLD)1984 Miller Dialarc 250HF, Miller water cooler, 250 AMP water cooled torch, you know the worx.
GMT+8, 2026-1-1 17:21 , Processed in 0.099002 second(s), 18 queries .
