Used Miller Spectrum 300
发表于 2021-8-31 22:20:04 | 显示全部楼层 |阅读模式
Im picking up a Spectrum 300 this morning that works is there anything to look out for also how hard is it to get the consumables for the torch i think it will be a good match for my handler 125 im sure i will want to upgrade it to the mvp at some point but it works for now.
Reply:well picked it up and paid a whopping $300 for it, works great ran it on my 4000 watt generator and cut good at 25 amps on painted 1/4" steel it has a slight air leak inside the machine havent looked into that yet ran it on 240 worked pretty good much cheaper than buying a oxy set up or cheap chink plasma cutter.  It even had the 20 ft torch on it not a bad find
Reply:great find !!!Lincoln Power Arc 4000 Thermal Arc Fabricator 252 iThermal arc 186Thermal Arc 26 tigTweeko 200 amp spool gunHobart AirForce 400WP-17V-12R
Reply:Thanks, it is pretty cool we have a 375 at work and it's pretty similar except for the torch I guess the 20' will be nice though
GMT+8, 2026-1-1 17:08 , Processed in 0.111334 second(s), 18 queries .
