How to tell the difference between F162 and F163
发表于 2021-8-31 22:20:03 | 显示全部楼层 |阅读模式
Are there any markings to tell the difference between an F162 and an F163?How much would a good running engine sell for?
Reply:supposed to be a tag on starter side of engine.other than that i don't knowdave
Reply:Oil fill tube is one external ID give-away.The early engine had a pipe oil fill tube with NPT cap.Later engine used a light tube and 1/4 turn oil cap.Good Luck
Reply:Here is what I'm working with. I guess with the oil fill cap looking like a pipe plug its a 162?I just noticed that the starter is mounted low too. Attached ImagesLast edited by shanghyd; 09-01-2009 at 06:57 PM.
Reply:162 starters will be down low and 163 starter will be higher up
GMT+8, 2026-1-1 17:01 , Processed in 0.071374 second(s), 18 queries .
