Idealarc SP150 feeds wire with trigger released
发表于 2021-8-31 22:20:03 | 显示全部楼层 |阅读模式
I have an older (late 80's?) SP150 that recently started continuing to feed wire after releasing the trigger.  The speed at which the drive roller turns is probably about 1/10th what it is when the trigger is pressed.  Depending on where the wire feed dial is set it feeds 1 to 2 feet of wire per minute.  The wire is not hot with the trigger released.  I disconnected the gun from the adapter as well disconnecting the trigger wire to eliminate the gun as a cause of the problem.  The problem persists.  Any ideas?
GMT+8, 2026-1-1 16:59 , Processed in 0.096446 second(s), 18 queries .
