Wp 225 - onan
发表于 2021-8-31 22:20:02 | 显示全部楼层 |阅读模式
Picked this up, swapped for O/A regulatorsWeldanpower 225DC with Onan CCK series, made in Australia.3 Kw continuousCarby was disconnected and in bits.As far as I can tell the only thing missing from the carb is the bowl.Looking to buy a carb kit and glass bowl.It is a marvel schebler vd 65.Cant locate anything over here.Cheers Attached Images
Reply:A Lincoln in Miller blue clothing!!  Cool.You could use an inline filter in place of the sediment bowl.  At least for now and keep looking for the glass if you're trying to stay original.Check with TJ (onanparts.com) on a carb kit.Planning a complete restoration Billy?MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Originally Posted by duaneb55A Lincoln in Miller blue clothing!!  Cool.You could use an inline filter in place of the sediment bowl.  At least for now and keep looking for the glass if you're trying to stay original.Check with TJ (onanparts.com) on a carb kit.Planning a complete restoration Billy?
Reply:Hey Billy, Nice find!I have confidence in ya, you will have that ole Lincoln a lookin good in no time!It looks to be in decent shape for its age, but that cable looks like it didn't weather as well!Good luck and keep us posted!One of these days I need to finish mine!Ken.#1. If you don't like what I wrote, or if it offends you, then don't read it!#2. I am living life the way I see fit, if you don't like the way I'M living, tough sh**!
Reply:looks like a nice little unit and a good trade for sure, never had one of those but always liked them and they do weld nice as I have used them. One thing I think I remember them using two batteries, either 6 volts or two 12's to get 24, can't remember. might want to check the lincoln site with your code #. Good luck , keep the pictures coming."Si Vis Pacem Para Bellum"Lincoln Idealarc 250 AC/DCMillermatic 251   Syncrowave 300   30A spoolgunLincoln MP210Hypertherm 45(2) LN 25(2) Lincoln Weldanpower 225 CV(4) SA200   1 short hood    SA250    SAM 400
Reply:Thanks guys.Will keep you updatedBilly
GMT+8, 2026-1-1 17:23 , Processed in 0.103818 second(s), 18 queries .
