SA 200 wide belt?
发表于 2021-8-31 22:20:01 | 显示全部楼层 |阅读模式
Changing to the GM altenator, do not have the original generator or pulley, what is the solution to use for a pulley on the GM altenator? GM pulley is to narrow, should I just use the narrow belt on the wide crank and water pump pulleys?"Si Vis Pacem Para Bellum"Lincoln Idealarc 250 AC/DCMillermatic 251   Syncrowave 300   30A spoolgunLincoln MP210Hypertherm 45(2) LN 25(2) Lincoln Weldanpower 225 CV(4) SA200   1 short hood    SA250    SAM 400
Reply:As long as the belt won't "bottom out" there should be no problem.Gordie -- "I believe you understand what you think I said, but I'm not sure you realize that what you heard is not what I meant."
Reply:Any serious truck parts, or electrical rebuild shop, should be able to cough up a wide groove pulley.Good Luck
GMT+8, 2026-1-1 17:00 , Processed in 0.107066 second(s), 18 queries .
