Got a new 140c
发表于 2021-8-31 22:20:01 | 显示全部楼层 |阅读模式
Well my Solar 2120 just wasn't cutting it anymore. I sold it for 50$ on CL. I got the 140c from Abco for 615$ on sale. Not too bad from what I have seen. Nice machine.Question:I have .32 wire for it but the tips I have are .35 How critical is that  ?Lincoln Ranger 8Lincoln 140c MigLincoln Tombstone(doesn't everybody have one ?)Miller 200Diesel/Heavy Equipment MechanicLead Plant Mechanic Municipal Water
Reply:.32?? If the dia of the wire is .032" then the the only tip available will be a .035" tip, you will have a problem with a .030" tip.Good Luck!
Reply:Thanks.Lincoln Ranger 8Lincoln 140c MigLincoln Tombstone(doesn't everybody have one ?)Miller 200Diesel/Heavy Equipment MechanicLead Plant Mechanic Municipal Water
Reply:I think he ment .023 wire LOLNice little welder. Have funMiller DVI2Lincoln Precision Tig 225Thermodynamics Cutmaster 38Everything else needed.
Reply:Personally, I wouldn't run the .023 wire in a .035 tip. In desperate times I have done so with no problem.
Reply:Hi; .032 wire dose Not Exist !!   Probably .023 !  .......... Norm :
Reply:Originally Posted by Canadian WeldorHi; .032 wire dose Not Exist !!   Probably .023 !  .......... Norm :
Reply:Originally Posted by jamlitExactly what I was saying. I don't know where the .035 tip thing came into it.
Reply:Got a new 140c --------------------------------------------------------------------------------Well my Solar 2120 just wasn't cutting it anymore. I sold it for 50$ on CL. I got the 140c from Abco for 615$ on sale. Not too bad from what I have seen. Nice machine.Question:I have .32 wire for it but the tips I have are .35 How critical is that ? Original poster's question, .35 tips?????????????
Reply:Ahhhhhhh. I missed that. SorryI agree that you shouldn't run .023 wire through a .035 tip. Again sorry mjedudeMiller DVI2Lincoln Precision Tig 225Thermodynamics Cutmaster 38Everything else needed.
GMT+8, 2026-1-1 16:59 , Processed in 0.106667 second(s), 18 queries .
