SP135 plus welder not working
发表于 2021-8-31 22:20:01 | 显示全部楼层 |阅读模式
this welder just one day stopped working right... i cant run any beads because it just kicks at me and leaves horrible looking welds.. any ideas?? i am a totally noob at welders
Reply:HiNeed more info.Have you looked at anything at all yet?Check all the easy things first.Do you have a manual?It will have a trouble shoot guide for the simple things
Reply:i dont have a manual.. and i havent really checked anything( i have no idea what to check)
Reply:Get the Code# off the ID tag and then go here:http://www.mylincolnelectric.com/Cat...ualsearch.aspxRex
Reply:i got the code and now i guess i have an online owners manual... and under troubleshooting it told me this... any other ideas1. Arc voltage may be set too low.2. Gun tip may be worn – Replace.3. Check for correct input voltageto machine.4. Gun or work cable may befaultyLast edited by RustBucketDA; 10-03-2009 at 11:01 AM.
Reply:Lets' start with the basics.What are you trying to weld and what are your settings on the machine? It sounds to me like the wire speed is too high or as they suggest in #1. Arc voltage is too low.What type and thickness of material are you welding?What Letter is the top dial (Voltage) set at?What # is the bottom dial (Wire Speed) set at?http://all-a-cart.comWelding Cart Kits and accessories
Reply:Originally Posted by ZTFabLets' start with the basics.What are you trying to weld and what are your settings on the machine? It sounds to me like the wire speed is too high or as they suggest in #1. Arc voltage is too low.What type and thickness of material are you welding?What Letter is the top dial (Voltage) set at?What # is the bottom dial (Wire Speed) set at?
Reply:Originally Posted by RustBucketDAthis welder just one day stopped working right... i cant run any beads because it just kicks at me and leaves horrible looking welds.. any ideas?? i am a totally noob at welders
GMT+8, 2026-1-1 16:59 , Processed in 0.099293 second(s), 18 queries .
