SP135 plus diode???
发表于 2021-8-31 22:20:00 | 显示全部楼层 |阅读模式
so i took my Lincoln SP135 plus welder apart and figured out that it needed diodes... anyway were do i get these diodes??? the code on the front of the welder is 10974 and U1031112991
Reply:Here's a possible source.http://www.nteinc.com/Web_pgs/Industrial2.htmlMM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Happens quite often. Check with Stumpfs.  www.stumpfweldingsupplies.com
Reply:these r what the diodes look like... i have no idea where to get them.. any ideas??
Reply:What you have RustBucketDA is shown as the 'current' design which appears to be serviced as a compete assembly per the parts break-down P-454-E. http://content.lincolnelectric.com//...parts/P454.pdfMM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
GMT+8, 2026-1-1 16:59 , Processed in 0.097854 second(s), 18 queries .
