Sa200 RPM
发表于 2021-8-31 22:19:55 | 显示全部楼层 |阅读模式
Is there any other way to adjust the rpms on a sa200 other than with the governor. My heat is good but my machine feels like it's running slow
Reply:Ocv when started first thing in the morning are 98 aux plug 123v rpm 1500. Rack is on factory punch marks. The machine welds like I want it with the rpms at 1525 but it makes the ocv way over 100 and the aux at 130v
Reply:When cold (below 50F) my unit OCV (Code# 8638) will start out around 104V but after welding awhile will settle in around the spec 95V with RPM at 1550 +/-.Depending on your Code#, auxiliary power OCV can be in excess of 130V - again, warm.OCV and Other Specs.pdfMM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Ok that's about how my machine does I was also worried about my grinders if I use the first thing when voltage is up around 130v
Reply:130V is still within +/-10% of 120V.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:I've also noticed whenever it's real cold, or cold and moist the arc on my machine runs real funky sometimes it seems like the pipe doesn't take the metal real good in these conditions
Reply:It all factors into the equation and adjustment in machine and/or technique are often required based on all current or changing machine, nature or operator conditions.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Preheat carbon steel to the point you see the surface moisture evaporate. Sent from my iPhone using TapatalkLong after the price is forgotten, the quality will remain.Both of my Poppy's 1954 Short Hoods -Third generation to weld with it and teaching a fourthSA 2## - Bought and sold more than I can remember or care to list, 8 in the shop right now
Reply:Originally Posted by Macb20I've also noticed whenever it's real cold, or cold and moist the arc on my machine runs real funky sometimes it seems like the pipe doesn't take the metal real good in these conditions
Reply:Thanks everyone I appreciate the info
GMT+8, 2026-1-1 17:00 , Processed in 0.093474 second(s), 18 queries .
