To buy a SA 200 Lincoln or not
发表于 2021-8-31 22:19:55 | 显示全部楼层 |阅读模式
I have a shot at a SA 200 but aren't sure about it never had one before.Its numbers are SA200-F-163  Code 7307  Ser #  A 7289?? Had some rust around serial #It started easy but the idle up control part didn't work Had torn rubber bellows around it.I guess on that setting the motor would rev to the correct rpm for welding.It would not strike an arc on the 1/8 6011 rod until the adjustment switch was set to 190 amps and revved up by hand.It seemed to run a soft arc then but I didn't get the chance to do much with it.Much of the visible wiring was dried out and brittle.The asking price is $2000 on a trailer,$1700 off it.Its my brother in laws and I would have to run back 400 miles to get it.Any advice or comments would be really welcome.Thank you.
Reply:What do you plan to use it for?Their just a big stick welder fuel hog.And yes, CEP, we know they can run a suitcase feeder, every bigger stick welder can.Just a couple welders, big hammers, grinders, and torches.Work will free you.Men in dirty jeans built this country, while men in clean suits have destroyed it. Trump/Carson 2016-2024
Reply:It’s a 1973. Does it have an octagon barrel? Attached ImagesDon’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:Originally Posted by AKweldshopWhat do you plan to use it for?Their just a big stick welder fuel hog.And yes, CEP, we know they can run a suitcase feeder, every bigger stick welder can.
Reply:Not for two grand. Not 400 miles away one way. Not with brittle, weathered wiring and other obvious problems. And definitely Not when you have to screw with it to get it to light up.Leave it there. Later machines are a dime a dozen and with oil hitting the skids, I imagine a lot of ppl will be looking to unload spare iron before too long.$2K in most cases should get you a clean, later model machine in good running condition. I've seen pre '70 red face machines with round barrels sell for that price in good shape, running and welding well, ROW ready.Let it be someone else's problem. If you want a machine to restore, there are far better candidates out there, earlier model copper wound machines with lots of promise for a quarter of their asking price.IMHO of courseLast edited by 7A749; 12-28-2015 at 04:42 PM.Expert Garage Hack....https://www.facebook.com/steven.webber.948
Reply:Man.  I gotta get in on this.Ran and welded great.  Missing a few parts, new battery box.  Won't last long at $3500!!!MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Expert Garage Hack....https://www.facebook.com/steven.webber.948
Reply:Originally Posted by AKweldshopAnd yes, CEP, we know they can run a suitcase feeder, every bigger stick welder can.
Reply:If Lincon and Everlast had a baby, what would it look like??? Expert Garage Hack....https://www.facebook.com/steven.webber.948
Reply:Originally Posted by CEPEven a little baby welder can run a suitcase feeder.
Reply:Originally Posted by AKweldshopI'm speaking amperage and duty cycle wise, not size.
Reply:Originally Posted by duaneb55Man.  I gotta get in on this.Ran and welded great.  Missing a few parts, new battery box.  Won't last long at $3500!!!
Reply:I just picked up an 86 sa250 running welding with lead for 450.. id pass if it was meMiller ab/p 330Hobart champ 16Miller 140Lincoln Power Mig 255Lincoln SA-250
Reply:5 $20 dollar bills. He should throw the trailer in for free.
Reply:A couple five-o rocks might get it done too Expert Garage Hack....https://www.facebook.com/steven.webber.948
Reply:Originally Posted by 7A749A couple five-o rocks might get it done too
Reply:Hehehe Expert Garage Hack....https://www.facebook.com/steven.webber.948
Reply:Thank you all.I'm going to walk away from this one.
GMT+8, 2026-1-1 16:59 , Processed in 0.218360 second(s), 18 queries .
