Needing some guidance....
发表于 2021-8-31 22:19:51 | 显示全部楼层 |阅读模式
I picked up an incomplete, but new, Victor Turbo Tote like the one here. It is missing a few parts, but I think it was a good deal if I don't spend too much putting this kit back together.I am missing:Key for acetylene tankHosesCheck valve (??or something like this to prevent flow back to tanks??)Mixing handlegogglesI got:ToteTanksGauges Tip "0" (what this is)Tip "000" (what this is)Tip "4" (hat this is)Torch Head CA 25StrikerTried going to Victors website to get manuals, but did not find anything.Needing some direction to get these correct components that are missing.The torch itself is a CA25 and I need help getting the correct mixing handle that ism missingANY advice on getting this back together and complete is greatly appreciated.Last edited by bondobridge; 08-28-2014 at 01:30 AM.
Reply:look up local welding supply shop, like an Airgas or Techair, and they ought to be able to help you out. You can get most of that stuff on the internet as well.http://store.cyberweld.com/vieq.htmlMiller Multimatic 255
Reply:Some newer Victor handles have the flashback/check valve in the torch handle.  Sure that cutting attachment isn't a CA-250?  If so, a medium-duty Victor handle should fit it. Are the tips welding or cutting tips?"USMCPOP" First-born son: KIA  Iraq 1/26/05Syncrowave 250 w/ Coolmate 3Dialarc 250, Idealarc 250SP-175 +Firepower TIG 160S (gave the TA 161 STL to the son)Lincwelder AC180C (1952)Victor & Smith O/A torchesMiller spot welder
Reply:Originally Posted by OldendumSome newer Victor handles have the flashback/check valve in the torch handle.  Sure that cutting attachment isn't a CA-250?  If so, a medium-duty Victor handle should fit it. Are the tips welding or cutting tips?
Reply:Grabbed a 100FC mixing handle that appears to have the flash arrestors integrated. Now hoses....
GMT+8, 2026-1-1 17:23 , Processed in 0.101625 second(s), 18 queries .
