Cast Stainless???
发表于 2021-8-31 22:19:49 | 显示全部楼层 |阅读模式
I found some cast 304 stainless pipe couplings. Can these be easily welded and used for bungs on a tig cooler water tank???
Reply:I haven't had any problems in the past welding on cast 304 pipe couplings.  I'm guessing you won't have any problems either.
Reply:A good casting will weld just fine.  I use these 304 SS cast flanges to build headers.  Dynasty 300DXSmith He/Ar gas mixerMM350PHobart Handler 120Smith LW7, MW5, AW1A
Reply:Where did you find those cast flanges? I've been looking for something like that for years.Give me fuel, give me fire, give me that which I desire.
Reply:http://ultimateheaders.com/cast-header-flanges.shtmlBubble gumTooth pixDuct tapeBlack glueGBMF hammerScrew gun --bad battery (see above)
Reply:no problems! I have been instructed to weld up more than a few cast threaded fittings that leaked. I believe socket weld fittings are cast as wellbosses stuff:trailblazer 325maxstar 200my stuff:sa 200fronius transpocket 180100 amp Lincoln w/f97 f350 DITKevin
Reply:Originally Posted by PrimetimeWhere did you find those cast flanges? I've been looking for something like that for years.
GMT+8, 2026-1-1 17:00 , Processed in 0.116439 second(s), 18 queries .
