FS: New Miller Passport Mobile Mig System, $1300
发表于 2021-8-31 22:19:46 | 显示全部楼层 |阅读模式
Unused Miller Passport 180 amps, self contained unit. Located near Toms River, NJPortability is number one when you have to go to the job - because it can't come to you.  Passport 180 contains all you need to MIG weld in one small lightweight packge. Self-Contained gas cylinder provides 25 minutes of welding time.  The cylinder holds 12 oz of CO2.  That's 25 feet of weld on 3/16" in thck material with .030" in mild steel wire.  The cylinder can NOT be used with mixed gases.  One empty cylinder is included with the systems. Auto-Line provides state of the art flexiblity to the end user.  The Auto-Line circuitry automatically connects to 115/230 VAC, single-phase power without removing the cover to relink the pwoer source.  No longer is ther a concern if you have the correct machine for the shop or job site. MILLER EXCLUSIVE- Multi-voltage plug (MVP) allows you to connect to common 115 or 230 V power receptacles without the use of any tools-- choose the plug that fits the receptacle and connect it to the power cord. Durable cast aluminum feedhead incorporates dual-groove quick change drive rolls and spring loaded tension arm with calibrated tension knob-all designed to make setup easier and faster. Handy side storage pouch for work cable and clamp, M-10 gun, MVP adapters and power cable. Carries 8 inch spool of welding wire. Impact-resistant case proivdes strength and durability,  protecting the internal components and welding wire. High-quality arc characteristics feature positive arc starts without popping and spatter, high stability low-spatter CO2 welding. With arc control, you can select between a crisp-arc weld suited for mild steel or a softer arc suited for stainless steel and some mild steel applications. Fan on demand, the fan only operates when the power supply requires cooling--saving power and keeping the inside clean. With the flip of a switch, dual gas supply selects between the internal CO2 gas supply when you're on the move, or bulk supply when you're in the shop (big cylinder).Comes complete with:Power cord and MVP adapter plugs for 115 and 230V 10 foot M-10 gun and cable assembly 10foot work cable and clamp One CO2 gas cylinder (empty) Two contact tips for .024 and two for .030 wire Dual groove quick change drive rolls for .024" or .030"/.035" wire
Reply:I have seen those and have been curious about the bottle?   do you refill them from a larger bottle, exchange them or just throw away and buy another one???Tiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
Reply:That bottle looks like a paintball gun bottle. Easily refillable if it is.ThurmondMiller Bobcat 3 Phase,26 series gas cooled TIG torchMiller Suitcase X-Treme 12VS17 Series Tig Torch for Solar Panel Powered WeldingOxy/Acetylene Torch rigEVERLAST PowerUltra 205P
Reply:Tritium is correct, they are paint ball bottles that can be filled at your nearest paint ball outlet, and I just saw them in Lowes looking for something else ok the tool bin area. I was thinking to make an adapter to refill also. But have a MM135 that I have been using. There is a fitting on the back for your regular bottle. Seems a 20cf size wouldn't be to hard to transport with it. This unit is brand new.
Reply:You can make or buy transfill adapters to refill paintball cylinders at home. Plenty of info online.
Reply:My portables are 40CF  pretty easy to transport.   It seems like you would run out of gas in about 5 or 10 minutes with that little bottle.  might as well just carry a roll of flux coreTiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
Reply:Its liquid C02 so it will last as long as he stated. Since it's in liquid form you can fit a whole lot more in there for the size since it will expand into a gas when it leaves the bottle. That's why it's measured in oz's and not by PSI. Pressure stays constant(until it starts to run out anyways)
Reply:BC is correct, also there is a built in switch inside to toggle from using the small bottle out in the field for a quik repair or carried for an emergency say on the trail, to using your large shop bottle if you are just gonna keep it in the shop. And when you need to grab n go with it, its always ready.
Reply:Sparkster,What is the serial number on that unit?Even though new, it appears that it is the older model (pre Passport Plus).  Does the unit still have warranty left?The Passport Plus represents a significant improvement over the previous models.  I haven't used the new Plus model, but it's supposed to be optimized for the use of CO2.. Also, enhancements were made to improve the Passports capability to weld aluminum.  It also comes "spoolgun ready".A new Passport Plus can be purchased from BR Welding for $1,599.  That includes a full three year warranty and free shipping anywhere in the US.The only reason I point this out is, you may want to reconsider your asking price.Syncro 250 DX Dynasty 200 DXMM 251 w/30A SG XMT 304 w/714 Feeder & Optima PulserHH187Dialarc 250 AC/DCHypertherm PM 1250Smith, Harris, Victor O/ASmith and Thermco Gas MixersAccess to a full fab shop with CNC Plasma, Water Jet, etc.
Reply:This is not a Passport Plus, that unit is capable of handling a spool gun, this one is not. Also if you want the spoolgun with the welder, this takes the price up to $1800.  So maybe if someone needs it for projects other than aluminum, it may not be a bad price. This unit uses CO2 in the portable tank, and if the remote port is used, can push any of the mixed gases and argon. I can't give a warranty since I am not a dealer, and this was purchased some time ago. As always, price listed was a starting point and IS negotiable. Hope I didn't mislead anyone.Last edited by sparkster; 07-10-2011 at 03:32 PM.
Reply:Thanks all for the interest, unit is no longer available.Last edited by sparkster; 07-11-2011 at 08:38 PM.Reason: SOLD
GMT+8, 2026-1-1 16:58 , Processed in 0.118957 second(s), 18 queries .
