drag cutting Spectrum 300
发表于 2021-8-31 22:19:44 | 显示全部楼层 |阅读模式
Doing some online research and looking in the manual I have found that the manual when explaining how to use the machine it says to place the tip on the material and start cutting.  When looking at consumables you can get the drag shield cup and all the necessary parts for the 27 which mine is the 25cx and accepts the same parts.  So can you drag cut with the factory consumables? or does it just reduce their life faster?Thanks  its quite a good machine for $300
Reply:92 views and no comments? am i doing something wrong that nobody will comment?
GMT+8, 2026-1-1 16:59 , Processed in 0.099140 second(s), 18 queries .
