Is this a decent horizontal bandsaw?
发表于 2021-8-31 22:19:41 | 显示全部楼层 |阅读模式
I can't find much info on it.  Made by Ang International.  Model #: BS-712N.  From what I can tell, it's manufacturered in China, which I'm not crazy about.  But I'm only in the market for something for occasional light duty cutting in my garage, so nothing too demanding.  I've just never heard of the brand and don't want to waste my money.  It looks like it would fit the bill though.  Bed:Bed Height From Floor: 22"Bed Width: 8-1/2"Vise Jaws Size: 11-1/4" x 4-1/4"Cutting Capacities:Round @ 90 degrees: 7"Rectangular @ 90 degrees: 7" x 12"Round @ 45 degrees: 5"Rectangular @ 45 degrees: 4-3/4" x 4-7/8"Blade:Blade Size: 93" long x 3/4" x 0.03"Blade Speeds (4): 88-134-193-255 fpmGeneral:Motor: 1 Horsepower, 0.75 kW, 110 Volt, 1,680 rpm, 60 Hz, Single PhaseElectrical: 110 Volt, Single PhaseOverall Dimensions: 47" x 15" x 38" tallI can't find anything on Craigslist within 200 miles of me, so this was my next best bet.  Let me know what you guys think. Attached Images"There are two types of people in America - those who try to classify everyone into two types and those who don't."
Reply:here's a post . http://weldingweb.com/vbb/showthread.php...581#post931581What's your budget ???
Reply:$500 or less.  I know that really limits me to almost nothing for a wet saw, but I don't mind used either.Is the ANG model above worth $500?"There are two types of people in America - those who try to classify everyone into two types and those who don't."
Reply:http://m.northerntool.com/northernto...?itemId=155793I own the saw list in the link above. I've got about $550 in it. It was a demo unit that was a year old floor model. Ive been extremely pleased with it. I wanted an american made comparable version, but was unable to find one for deal I got on this one.Other than the controls, I see alot of similarities between the two.
Reply:00never heard of it but i sure it's similar to the other imports. However I would look at Grizzly. They have some good reviews on here. you can search where you posted here and get more info.  What about this ??? http://www.baileighindustrial.com/sa...on/bs-128m.php
Reply:I like the space savings aspect of that Baileigh, but I'd like a wet saw.  I'll mostly be cutting solid round stock, so coolant is almost a must.I just found a new wet saw listing on CL about 150 miles away and it's cheap!  I'm probaby going to drive over there on Sunday to check it out."There are two types of people in America - those who try to classify everyone into two types and those who don't."
Reply:A dry saw will cut great if you use it properly. Ive been running two ellis saws in my shop for years with no problems due to the lack of coolant. we cut 6" stainless i beams all day friday and blade is fine. I dont miss coolant running through tubing and all over the floor, or having to wipe every single piece off before welding.
Reply:Originally Posted by Eric CA dry saw will cut great if you use it properly. Ive been running two ellis saws in my shop for years with no problems due to the lack of coolant. we cut 6" stainless i beams all day friday and blade is fine. I dont miss coolant running through tubing and all over the floor, or having to wipe every single piece off before welding.
Reply:Originally Posted by Scott Youngyep, I have been cutting dry for a couple years now.  Just slower cutting speed.  set it up and walk away for a really big cut.  Now if you are in production mode, then yes, time is money and wet cutting is a must.
Reply:Wish i could find a deal local like that
Reply:I have that same RongFu, it will serve you well. I bought a few different coils of blades for mine. I use 4tpi for solids and 18tpi for tube. I have other blades, but those see the most use.
Reply:Yeah, it seems to cut very accurately.  I only gave $250 for it and it came with 6 extra blades."There are two types of people in America - those who try to classify everyone into two types and those who don't."
Reply:Originally Posted by SuedePflowWhat's a good blade speed for cutting aluminum?  And how about cold rolled?
Reply:I'm going to pick one of these( the northern tool version) up in the morning if everything looks good...Last edited by DemonSpeeder; 04-05-2012 at 12:07 AM.Lincoln pro mig 180Lincoln Square Wave Tig 300/wp 20/home built water cooler Victor, Purox, Harris, O/A welding/cutting setupsVintage Craftsman drill pressVintage Craftsman/Atlas 12"x 36'' lathe7''x 12'' w/c band saw Everlast 140 st
Reply:Well I got my new machine today...What blades are you guy's running in dry mode???Lincoln pro mig 180Lincoln Square Wave Tig 300/wp 20/home built water cooler Victor, Purox, Harris, O/A welding/cutting setupsVintage Craftsman drill pressVintage Craftsman/Atlas 12"x 36'' lathe7''x 12'' w/c band saw Everlast 140 st
GMT+8, 2026-1-1 17:23 , Processed in 0.103813 second(s), 18 queries .
