Lincoln weldandpower g7 auto-idle
发表于 2021-8-31 22:19:40 | 显示全部楼层 |阅读模式
When I try to strike an arc, the engine does not go to full speed..Stays in idle..I can get itto full speed by the flipping up the high speed switch which you would do to use thegenerator..Welds fine then..Any ideas..Thanks
Reply:Could be idler board, switch, current sensor, or if in CV mode some work some do not.Check all wires at idler board, may be just a dodgy connection somewhere.
GMT+8, 2026-1-1 17:23 , Processed in 0.074071 second(s), 18 queries .
