Red Face Question SA 200
发表于 2021-8-31 22:19:39 | 显示全部楼层 |阅读模式
Bought An SA 200 that has a black face on it...guys says its a redface. How do i check to make sure..?
Reply:Run the numbers on face plate, code, serial. look for # on barrel1990 SA 200Miller 225  Rip Miller302Miller 135Lincoln 200 MigHypertherm 600 PlasmaPlasma Cam Cutting TableMikita Cold SawJL Welding Tx . com
Reply:Probably easier to just take a look here http://www.aws.org/cgi-bin/mwf/forum...ime&order=desc for the answer.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Somebody do me a favor and define the word "redface". Note that Lincoln themselves have never used this term and it was apparently coined by consumers but no one can seem to give me an effective defintion that makes sense.   THANKS
Reply:the red comes from the color of the "face plate" on the machine either red or black
GMT+8, 2026-1-1 17:23 , Processed in 0.073822 second(s), 18 queries .
