Lincoln G9PRO Project or Parts
发表于 2021-8-31 22:19:38 | 显示全部楼层 |阅读模式
Number two of three that followed me home today.It's a runner but the face was sucker punched and shorted out the range switch. Melted one of the output cables in half. Checks OK with the DVM but I'll hit it with a megger tomorrow and check all the windings.About a 1988 model with a new replacement Onan P218 back in 2000. This is one of Lincolns absolute BEST portable welders in it's class. Almost bullet proof. Over the years it's been very rare that I ever had to go inside a G9PRO for anything other than checking the brushes and cleaning slip rings. With the 18HP Onan 275 amps is typical. This one will get a light overhaul if the windings turn out OK and a 20HP cam and main jet. 280-300 amps with a couple extra ponies is possible.I don't think I have enough winter projects to keep me busy! Attached ImagesMiller LegendMiller XMT 200Miller HF 251DMiller Spoolmatic 30AMillerTrailBlazer 250GLincoln LN 25Lincoln G9 ProLincWelder 225Lincoln Ranger 9Lincoln Ranger 275TJhttp://onanparts.com
Reply:Man TJ!  They just keep coming and coming!Can't get folks to part with 'em down here.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
GMT+8, 2026-1-1 17:00 , Processed in 0.098103 second(s), 18 queries .
