Got bored the other day....lol
发表于 2021-8-31 22:19:36 | 显示全部楼层 |阅读模式
Well the other day we finally made it to the point where we needed to build the headers for a buddies 1940 ford sedan we're building on the weekends so I broke out my laptop and auto cad and got after it took me a while but got the 3d model done then yesterday I got the driverside header fitup and I must say it's turning out very cool....Overkill is underrated.....
Reply:Right sexy!Regards,RobGreat Basin WeldingInstagramBlue weldersRed weldersMy luscious Table DIY TIG Torch cooler
Reply:nice !!!Thermal Arc  Power-Tech 10/270  stick welderLincoln buzz-boxPurox O/A setupNothing is foolproof to a sufficiently talented fool
Reply:Looking good !Thermal arc 211iCk flex-loc 150 & 130Clamps, saws & grindersHarbor freight 80 amp inverter
Reply:Chebby in a Ford....Naughty Naughty.......zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Ford makes it chevy shakes it....  Hey y'all it's a fordolet.....lol. Overkill is underrated.....
Reply:Originally Posted by zapsterChebby in a Ford....Naughty Naughty.......zap!
Reply:Looks like you are on your way.  Thanks for sharing
Reply:Very nice!
Reply:It's a whole lot more expensive to build a naturally aspirated 600 hp sbf to run on 92 octane than a sbc besides the only thing left ford on this car is the shell cause fatman fabs built the chassis....Overkill is underrated.....
Reply:Originally Posted by chevyracer8262It's a whole lot more expensive to build a naturally aspirated 600 hp sbf to run on 92 octane than a sbc
Reply:I like the 4 pipe!I would guess that is the only exhaust that POSITIVELY uses 4 pipes ALL the SAME length!
Reply:Yea that one was fun to figure out how to run....  But the time I spent building the 3d model really paid off cause I had to trim only 1/4" off the 2 straights to make them fitOh and by the way I built sbf's before too and out ran a lot of bbc's but I'm a Chevy man at heart.  I personally have a 69 chevelle with a 550hp full roller Spfi 383 going into it that'll also run on 92 octane...  Overkill is underrated.....Last edited by chevyracer8262; 07-01-2014 at 08:13 AM.
Reply:Very nice work!!!Is there a star shaped piece that goes into the centre of the 4 pipes before they are inserted into the larger single one?Not sounding right. To fill in the voids between the 4 tubes for sealing?Cheers.
Reply:Most headers that I've looked at have those tubes pinched together and welded out but I'm going to look into that once I get the tubes welded and make it to that pointOverkill is underrated.....
Reply:Ford makes it, Chevy recalls it.Good lookin headers!
Reply:Originally Posted by vwguy3Ford makes it, Chevy recalls it.Good lookin headers!
Reply:That # 4 tube has too sharp of a bend & it's not going to be as efficient as the other 3 tubes.  Have to do some balancing further down on the exhaust to help it.MarkI haven't always been a nurse........Craftsman 12"x36" LatheEnco G-30B MillHobart Handler 175Lincoln WeldandPower 225 AC/DC G-7 CV/CCAdd a Foot Pedal to a Harbor Freight Chicago Electric 165A DC TIG PapaLion's Gate Build
Reply:Nice pipes!"All of this and some of that's the only way to skin the cat!"
Reply:Sharp work! I built a few sets for 3800 FWD cars a few years back, and getting em right is a B!Sent from my iPhone using TapatalkUsing Tapatalk
Reply:Yep it isOverkill is underrated.....
Reply:FORDVROLET Everlast PowerARC 300
Reply:Nice work! I agree with mark, go back to the drawing board and eliminate the hairpin on #4.you'll wish you did after you measure the additional heat that sharp bend creates at the head.
Reply:What a real nice fabrication project! Nice weld on the pipes. It was a productive day!Old tools, trajan band saw, grizzly, delta,lincoln
Reply:Got to looking at the headers and decided to mod the 4th tube a little so it would clear the body better I took out one of the 90's added more straight and replaced the 90 with a 60 and worked like a charm....Overkill is underrated.....Mmmmm.... Pretty!Sent from my iPhone using TapatalkUsing Tapatalk
Reply:Originally Posted by chevyracer8262Got to looking at the headers and decided to mod the 4th tube a little so it would clear the body better I took out one of the 90's added more straight and replaced the 90 with a 60 and worked like a charm....Overkill is underrated.....
Reply:Now #3 tube, will that interfere with the steering shaft?  # 4 tube looks much better, but those 90* bends are gonna get red hot at full throttle.MarkI haven't always been a nurse........Craftsman 12"x36" LatheEnco G-30B MillHobart Handler 175Lincoln WeldandPower 225 AC/DC G-7 CV/CCAdd a Foot Pedal to a Harbor Freight Chicago Electric 165A DC TIG PapaLion's Gate Build
Reply:I'm really digging that suspension made out of copper pipe.Mr. HE
Reply:The purpose for running the tubes over the frame rather than inside is to give clearance to the steering shaft, there's not going to be any issues clearing them and as far as plugs go there's plenty of room to get to them from either up top or underneath...  Which is why I plan to run the wires with those under header looms...  And as far as getting hot we already plan to have them ceramic coated inside and out as well as any areas that'll get close to the tires will be wrapped with header insulationOverkill is underrated.....
Reply:Here's a little update, the driversides completely finished.... After final fitup we took some measurements and the longest tube is within 1/2" of the shortest tube so I'd say those are and close to equal length as it gets Attached Images
Reply:I think we need a new rule.  If you post header shots,  you have to post a sound bite as well.  Nice work!Regards,RobGreat Basin WeldingInstagramBlue weldersRed weldersMy luscious Table DIY TIG Torch cooler
Reply:Had to go out of town for work so it's Been a little while but here's some updated pics....  It's finally ready for final weldout....And here's a little shop of the lightweight welding table I built to have something at my buddies garage to do the header and sheet metal fab work on....Overkill is underrated.....
Reply:Coming along Great! Nice work. What kinda car, or did i miss it like a bonehead.I hate being bi-polar it's awsomeMy Heroes Have Always Been Cowboys
Reply:Just saw it. Im a bonehead I hate being bi-polar it's awsomeMy Heroes Have Always Been Cowboys
Reply:Awesome build!  Very impressive exhaust work to.  X2 on posting a video with sound when she is up and running!  GarLincoln Electric, Power MIG 256Hypertherm Powermax 45 Miller Dynasty 280DXSmith O/A torchGenesis of a welding table
Reply:I can't wait to hear it myself it's gonna be obnoxious especially with the near 600hp street/strip 408cuin sbc it's getting....  Just found out nitroplates gonna be down here for cruisin the coast so I'm gonna knock them out this weekend so we can drop them off at their booth for them to take back to their shop for coating...Overkill is underrated.....
Reply:Who gets to run the steering shaft now? Nice header work! Love the old hot rods!12v battery, jumper cables, and a 6013.I only have a facebook page. https://www.facebook.com/pages/VPT/244788508917829
Reply:Originally Posted by VPTWho gets to run the steering shaft now? Nice header work! Love the old hot rods!
Reply:Steering shafts going to be easy to run that's the reason I built the headers to go outside the frameOverkill is underrated.....
Reply:Well the headers came back from nitroplate today.....  Turned out great...,Overkill is underrated.....
Reply:Really Nice headers that you fabbed up there sir...I like em. I love LOUD pipes.Quality work is never Cheap, and Cheap work is never Quality!!If it's broke, and you're not, we can fix it!!  Lincoln Idealarc sp200Century 230amp ac/dcSmith O/A TorchesHuth Hyd. Pipe Benderother misc "cool" tools
GMT+8, 2026-1-1 19:20 , Processed in 0.180695 second(s), 18 queries .
