查看: 13|回复: 0
Stupid question deserves a great response!
发表于 2021-8-31 22:19:30 | 显示全部楼层 |阅读模式
I just seen one of my boys dragging about a 20 foot piece of 3/8" chain across the yard, I asked him........."why are you dragging that chain across the yard?"..........he said...."have you ever tried to push one?"I spit my coffee all over myself laughing and just walked away..................6 Miller Big Blue 600 Air Paks2 Miller 400D6 Lincoln LN-25's4 Miller Xtreme 12VS2 Miller Dimension 812 4 Climax BW-3000Z bore welders Hypertherm 65 and 85Bug-O Track BugPair of Welpers
Reply:LMAO...that is todays youth......Of all the things I lost I miss my mind the most...I know just enough about everything to be dangerous......You cant cure stupid..only kill it...
Reply:Awesome Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:He's definitely pulling your chain.If I only saw my boys pulling my chains all over the yard, then I'd actually know where they were when I needed one...RyanMiller Multimatic 200 tig/spool gun/wireless remoteMillermatic 350P, Bernard/XR Python gunsMiller Dynasty 350, Coolmate 3.5 & wireless remoteCK WF1 TIG wire feederMiller Spectrum 375 XtremeOptrel e684Miller Digital EliteMiller Weld-Mask
Reply:It IS possible to push a chain, you just have to wad it into a ball first to do it and it won't be laid out in a straight line while doing it. If it HAS to be in a straight line while pushing it, well that's another story.
Reply:Originally Posted by BistineauIt IS possible to push a chain, you just have to wad it into a ball first to do it and it won't be laid out in a straight line while doing it. If it HAS to be in a straight line while pushing it, well that's another story.
Reply:When I worked on the land, I had a good tow chain I kept on my crawler. A guy borrowed it to tow a cement truck out with a backhoe loader, and when it came back they'd snatched and stretched it so much it was rigid. You could have pushed that chain.
Reply:Good answer by the kid means he scored dads chain
GMT+8, 2026-1-1 21:11 , Processed in 0.098906 second(s), 18 queries .
