Farmer looking to purchase new Tig/Stick
发表于 2021-8-31 22:19:30 | 显示全部楼层 |阅读模式
Hello all! Hope your Holidays went Great! About to choose between an Everlast 255 EXT ac/dc or the 325 EXT ac/dc with water cooler and stand and torches. the 255 goes down to 5 amp to 255 as the 325 will only go down to 10 amp. Should this deter me from the 325 or should I just bite the bullet. I currently have a miller 212 mig and a lincoln 305 portable and an older lincoln 180 stick in the old shop. I priced the miller 280 and same equipment but it is almost 2.5 times as much money. Any opinions or help would be appreciated.
Reply:I sure am happy with Miller.An optimist is usually wrong, and when the unexpected happens is unprepared. A pessimist is usually right, when wrong, is delighted, and well prepared.
Reply:I have been happy with my miller 212 mig ...just wish I would have bought the 252. that being said 5 year warrantee and 3000 instead of 9400?
Reply:you might want to read the many threads on the everlast and chinese welders here before you buy.....Of all the things I lost I miss my mind the most...I know just enough about everything to be dangerous......You cant cure stupid..only kill it...
Reply:To get the best recommendation, tell us what you will be using it for primarily, type of metal, how thick of material, how often Will you use it.  does it need to be portable? R u willing to look at used machines? Etc.Tiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
Reply:Well It will be used for shaft rebuilds, sometimes T1, stainless, Aluminum, some tungsten, and who knows, but I would not like to limit. I have a Lincoln 305 for portable stick stuff and supply tig if necessary. The thickness can vary from pop can to .75 inch...any more can do multiple passes. I have been watching for used but used is used usually no warranties and not that many up here right now. U. S dollar is a 30 -40% loss right off the top over Canadian currency!Last edited by Plowjockey; 01-06-2016 at 06:41 PM.
Reply:Member here Pine just bought an Everlast 325 EXT. When he gets a hole in his work schedule he is going to bring it to my shop so I can help him with his Tig welding. I own a couple SMAW welders of Everlast, and I got to run one of their 120-volt Mig welders. For the money I’m very impressed with their SMAW welders.Don’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:Originally Posted by PlowjockeyWell It will be used for shaft rebuilds, sometimes T1, stainless, Aluminum, some tungsten, and who knows, but I would not like to limit. I have a Lincoln 305 for portable stick stuff and supply tig if necessary. The thickness can vary from pop can to .75 inch...any more can do multiple passes. I have been watching for used but used is used usually no warranties and not that many up here right now. U. S dollar is a 30 -40% loss right off the top over Canadian currency!
Reply:Welcome fellow Canadian farmer...PM sent.
Reply:I would rather have a high end dc unit. Do you really have that much use for ac?
Reply:Originally Posted by mikecwikI would rather have a high end dc unit. Do you really have that much use for ac?
Reply:Originally Posted by soutthpawHe wants to weld aluminum Sent from mobile.  Not responsible for Typos
Reply:Everlast 250ex is a great machine for $1600I'd skip the 255, all those stupid bells and whistles you don't even need.Just a couple welders, big hammers, grinders, and torches.Work will free you.Men in dirty jeans built this country, while men in clean suits have destroyed it. Trump/Carson 2016-2024
GMT+8, 2026-1-1 19:21 , Processed in 0.156929 second(s), 18 queries .
