Optima Programming
发表于 2021-8-31 22:19:28 | 显示全部楼层 |阅读模式
Does anyone here have programming parameters they've created that work well with their Optima pulses?The preprogrammed ones are all canned to specific wire sizes and gasses.  I've got C5 gas for spray, C25 for SC, and 100% argon.  Apparently pulsed mig is for use with spray only, so almost no spatter and lower heat input than traditional spray.  Wondering what those with an Optima have discovered work well in their experiences.  I'm looking for a general program for .030 steel wire.  BTW, I'm using an XMT304 with an S22 suitcase and a Q300.  Also a WC24 with a Spoolmatic 30 amp.Thanks
Reply:I'd suggest just using the manual setting option and play around with it.  Section 3-7, page 9 of the manual outlines how changing parameters affect arc and burn-off rate to give you an idea of what to expect.https://www.itwwelds.com/miller/serv...(KG285399).pdfMM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
GMT+8, 2026-1-1 19:22 , Processed in 0.107784 second(s), 18 queries .
