Can a SuperFlex cable be installed on this torch?
发表于 2021-8-31 22:19:28 | 显示全部楼层 |阅读模式
I have 17, 26, TL210 & CS310 torches but always wanted a 9 but never had a project to justify one.Was at the flea market and saw the power cable laying outside a box and to my supprise there was a 9v torch on the end with a gas lens! The guy wanted $10 so I didnt even think about it.The cable is real short and stiff so I was wondering if a Superflex Cable could be installed. I know my CK TL210 takes a special thread and I have not checked the thread on the 9 yet.TOO MANY TOOLS & NO MORE SPACE
Reply:Absolutely.  It is a standard 3/8-24 tpi female fitting on the torch.  Call up HTP.  Assuming your machine uses DINSE connector, the DINSE connector from the superflex hose package has to come with a gas-thru port where your gas outlet would feed.  Then it all travels within the 1-pc superflex cable.Last edited by Oscar; 09-06-2014 at 05:21 PM. 1st on WeldingWeb to have a scrolling sig! HTP Invertig 400HTP Invertig 221HTP ProPulse 300HTP ProPulse 200 x2HTP ProPulse 220MTSHTP Inverarc 200TLP HTP Microcut 875SC
Reply:Thanks Oscar, will have to give them a call.I am running it on an XMT and my TL210 with the Superflex cable has a gas hose running out of the power block to the regulator (no solenoid on machine/valve on torch) and there is a Lenco-Dinse plug on the machine. I will set up the 9 the same way. Sent from my GT-P3113 using TapatalkTOO MANY TOOLS & NO MORE SPACE
Reply:Originally Posted by 7A749Just get a SuperFlex like Oscar said from HTP.You'll want the Dinse connector with the separate gas hose on it. Mine, you can unscrew the ferrule and remove the hose to put whatever size you want on it providing it's the 1/4" dia hose..  The shell splits and has a collar that screws on to hold it together. Everything fits in there.
Reply:Here's a couple links, this should be what you need. http://www.amazon.com/s/ref=nb_sb_no...2Ck%3A57y01rsfhttp://www.amazon.com/CK-Worldwide-S...eywords=Sl2-35Thermal arc 211iCk flex-loc 150 & 130Clamps, saws & grindersHarbor freight 80 amp inverter
Reply:Originally Posted by Austin BennettHere's a couple links, this should be what you need. http://www.amazon.com/s/ref=nb_sb_no...2Ck%3A57y01rsfhttp://www.amazon.com/CK-Worldwide-S...eywords=Sl2-35
Reply:Originally Posted by 7A749Check with HTP. They prolly got it cheaper than anyone else. I bought my CK torch from Arc Zone and wished I hadn't.Been happy with all my purchases and they treat me well.
GMT+8, 2026-1-1 21:11 , Processed in 0.072347 second(s), 18 queries .
