查看: 13|回复: 0
Idealarc 250 $300. SC, C-list (not mine)
发表于 2021-8-31 22:19:23 | 显示全部楼层 |阅读模式
http://greenville.craigslist.org/tls/2474926953.htmlMmmmm.....AC/DC round top goodness. ITEM Idealarc 250 Arc WelderMAKE LINCOLN®MODEL 250-250CODE 904YEAR --SPECIFICATIONS / DESCRIPTIONRated Input Single phase -- 60 Hz -- 230/460V70-35 Amps @ 200 Amp 30V Load86-43 Amps @ 250 Amp 30V LoadRated Output 250 Amps @ 30 Arc Volts30% Duty Cycle72 Max. OCV @ Rated Input VoltageThis welder is a true workhorse. I used it for years but have recently downsized my shop and no longer have a need for it. I used it on 460 volt and it welds like a dream. They don't make them like this any more, so if youwant a good welder for a good price, don't let this one slip away. Welder does not come with the leads but will accept any standard welding lead. Call Allen at 864-607-7444.
Reply:Yes, I've seen a few Idealarcs for sale up here too... and at similar prices ($250 - $350) for the really old ones... but they always seem to be 400+ miles from my location!Rick V 1 Airco Heliwelder 3A/DDR3 CTC 70/90 amp Stick/Tig Inverters in Parallel1 Lincoln MIG PAK 151 Oxy-Acet
Reply:If I ever find one for sale close to me, I'm going to jump on it.
GMT+8, 2026-1-2 00:35 , Processed in 0.099411 second(s), 18 queries .
