Spanking the rebuilt loadbank with 450 amps on a Lincoln Vantage 500. I need to make some tweaks to the bank as the Vantage should hit 575 amps @ 35 volts. It did 450 @ 50 volts so I'll put some taps on the bank to lower the voltage/resistance and increase the amps up closer to rated output. Even at 450 amps it was not getting hot so it should be able to handle 600-700 amps no problem.One thing the digital meter can't do is "swing" like an analog! Miller LegendMiller XMT 200Miller HF 251DMiller Spoolmatic 30AMillerTrailBlazer 250GLincoln LN 25Lincoln G9 ProLincWelder 225Lincoln Ranger 9Lincoln Ranger 275TJhttp://onanparts.com
Reply:One thing the digital meter can't do is "swing" like an analog!You can say that again! Analog meters still have their place.Neat Loadbank! Were did you get the wirewounds at?Happy T-Day,John
Reply:Sweeeeeeet!MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Originally Posted by J. StrunckOne thing the digital meter can't do is "swing" like an analog!You can say that again! Analog meters still have their place.Neat Loadbank! Were did you get the wirewounds at?Happy T-Day,John |
