AC output problem w/Weldanpower 225
发表于 2021-8-31 22:19:14 | 显示全部楼层 |阅读模式
Currently have a Weldanpower unit  Code 9108  MDL AD-225/DC-210/6   attempting to use as generator and can only get 90 volts of output, at first glance the only thing I have noted is that the brushes appear to be very worn.  Can the worn brushes  be a factor?Any suggestions would be appreciated.
Reply:Yes, worn brushes and/or dirty slip rings can affect welder/generator output but also check the engine speed (should be 3600rpm) and depending on the AC load, assure the Fine Current Control is set to maximum.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Are the slip rings what the brushes contact with?  I did notice that they are not uniform in color. Some brass/copper showing, other areas are grayish.  Can they be cleaned?  Also do you know where I can purchase new brushes?Thanks for the help.
Reply:Originally Posted by ruinsane2Are the slip rings what the brushes contact with?
Reply:Thank you for the info, are there any tricks to the brush installation? I am handy but always look for advise to ease the process.
Reply:Nothing special and pretty straight forward.  You may or may not find it easier to remove the entire brush holder assembly and it can be done either way.  Just check for a good fit to the slip rings and contour the brushes to the rings by wrapping your sand paper (sanding side out) around the slip rings under the installed brushes and rotate in the proper direction of rotation.  This only needs to be done if the replacement brushes aren't properly contoured to begin with.FYI, This is what dirty slip rings look like.If the brushes are stuck in the holders (due to rust as these were) you'll need to pull the entire assembly out to remove them up and clean out the rust.  Yours should look similar and I use a nut on each of the anchor bolts to keep the assembly together while working on it.All cleaned / freed up and reinstalled.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Thank you for all the input.  Already ordered the new brushes from onanparts.com.  Will be up and running soon.
GMT+8, 2026-1-1 21:12 , Processed in 0.069040 second(s), 18 queries .
