LN-25 gas conversion
发表于 2021-8-31 22:19:14 | 显示全部楼层 |阅读模式
Hey all...Has anyone in here installed the gas conversion solenoid into a ln-25? I've acquired a code 10556  ln-25 for free believing it didn't  work but it actually does. It has no contactor or solenoid and the lincoln kit is in fact not free. However, I assumed that because the feed motor was 24v the output to the solenoid would be to. I seem to be wrong. The dc voltage at the PC board plug for the gas valve is 115vdc. I'm hoping somebody here has noticed if the lincoln kit has a voltage dropping resistor with a 24v solenoid or has a 115vdc solenoid or any other explanation....
Reply:http://content.lincolnelectric.com//...r/im/IM620.pdfEd Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:Thanks, read that...Problem resolved, circuit reads way high when on a cc source. Tested on a cv source @ 23v and the solenoid voltage read 24v. good nuff'
GMT+8, 2026-1-1 21:12 , Processed in 0.098992 second(s), 18 queries .
