few problems with my 250 G9 pro
发表于 2021-8-31 22:19:13 | 显示全部楼层 |阅读模式
Hey guys im glad i found this site ! I have an older G9 Pro and It welds great but when it idles down it surges up and down . At wide open it runs great it just wont stay at idle .  Also the dial to control the amps is hit or miss you have to play with it to get it to work when you change the setting .  If anyone has parts for this model id be interested in a good gas tank and a muffler assembly                       Thanks Bart
Reply:Try Stumpfs, they have many used parts and could most likely help you with your idle problem. 618-566-4733 or www.stumpfweldingsupplies.com
GMT+8, 2026-1-1 21:12 , Processed in 0.106546 second(s), 18 queries .
