I don't post alot of my projects as I'm generally not satisfied with the outcome, plus it takes a lot of time, but this came out OK.14yrs in this "shop" and I never had a stool, and I'll tell you what; if you don't have a stool, get ya one! These things are cool as hell!!Started with 1"1/8" "all thread". I think it was used for tying wall forms together.Didn't have a nut though, so "late nite" planning had me order one from McM/Carr. I ordered the wrong one though, due to not being able to tell left hand from right hand threads (this relates to my late nite machining blunder in another thread)Like my stack of dimes?The rest progressed as expected. Attached ImagesLincoln SA 200Esab Caddy 160Thermal Arc 201TSMiller Dialarc HFI don't like making plans for the day because then the word "premeditated" gets thrown around the courtroom....
Reply:I had a hellova time with porosity, even ground out some welds 3 times to no avail. I know its due to my lack of prep, but also what I "thought" was stainless rod, wasn't.Some welds I went over with bronze, but ended up switching to 309 filler. Attached ImagesLincoln SA 200Esab Caddy 160Thermal Arc 201TSMiller Dialarc HFI don't like making plans for the day because then the word "premeditated" gets thrown around the courtroom....
Reply:Rest of the project.Ak', I don't know how you did that flatbed thread. This typing, picture taking, organizing stuff sure is a PITA! Attached ImagesLincoln SA 200Esab Caddy 160Thermal Arc 201TSMiller Dialarc HFI don't like making plans for the day because then the word "premeditated" gets thrown around the courtroom....
Reply:Seat assembly and shameless plug for Airco. Attached ImagesLincoln SA 200Esab Caddy 160Thermal Arc 201TSMiller Dialarc HFI don't like making plans for the day because then the word "premeditated" gets thrown around the courtroom....
Reply:Is acme considered as all thread. Yes I guess that it is but I never thought to describe it that way.That nut is interesting.
Reply:Stool looks go but you need more that three feet on it now days 5 minimum 6 better . that way if you fall asleep you don't fall over
Reply:Originally Posted by mikecwikIs acme considered as all thread. Yes I guess that it is but I never thought to describe it that way.That nut is interesting.
Reply:Originally Posted by gxbxcStool looks go but you need more that three feet on it now days 5 minimum 6 better . that way if you fall asleep you don't fall over
Reply:Three legs is good without the casters but a killer with them...you don't have to tell me how I know.Measure with a micrometre, mark with chalk, cut with a torch.Never force anything...just get a bigger hammer.RoyOld Airco buzz box approx 1974Lincoln mig pack 15Lincoln 175 square wave1954 9" south bend lathe
Reply:Originally Posted by dubl_tYea Mike, I wondered if it was an Acme thread, but its got a rounded shape; whereas I thought Acme threads were more trapezoidal.I don't know. The super was tossing 20' of this, so I took it home.
Reply:Looks good. How long did it take to make?Craftsman 90 amp Arc welder
Reply:Originally Posted by lighttekkuLooks good. How long did it take to make?
Reply:Originally Posted by dubl_tshameless plug for Airco.
Reply:Originally Posted by DSWI'm sure they'd appreciate this, other than the fact they went out of business years ago. I think your plug is coming just a tad too late to be of any help....
Reply:Lol, got the nut I ordered.Wrong thread, wrong size, wrong everything! But it was only a $13 lesson.BTW, it's a 1" 4tpi acme thread. I'll find some use for it. Attached ImagesLincoln SA 200Esab Caddy 160Thermal Arc 201TSMiller Dialarc HFI don't like making plans for the day because then the word "premeditated" gets thrown around the courtroom....
Reply:Allrighty, took some creative engineering but I got the 3 leg issue resolved! Attached ImagesLincoln SA 200Esab Caddy 160Thermal Arc 201TSMiller Dialarc HFI don't like making plans for the day because then the word "premeditated" gets thrown around the courtroom....
Reply:That rounded threaded rod is used in concrete forms , and they do make some big nuts for it , It is Dayton Superior coil rod and is 1/2" to 1 1/2" dia. up to 12 feet long.
Reply:Nice chair. The nut you used looks like a helicoil. I guess you made it since your threads were reversed. Nice save.
Reply:I like the warning labels.
Reply:There are several different threads for the all-thread rebar. http://www.williamsform.com/Threaded...aded_bars.html"USMCPOP" First-born son: KIA Iraq 1/26/05Syncrowave 250 w/ Coolmate 3Dialarc 250, Idealarc 250SP-175 +Firepower TIG 160S (gave the TA 161 STL to the son)Lincwelder AC180C (1952)Victor & Smith O/A torchesMiller spot welder |
