Weld Test
发表于 2021-8-31 22:19:03 | 显示全部楼层 |阅读模式
Attachment 838071Here is a weld test i did today using a Lorch mig plant with 1.2mm wire on 10mm mild steel plate multi run.  The tee fillet was certainly easier than the full pen butt weld using same material and set up, but after 25 years I finally have to be coded to weld in the uk .  I suppose it will sort out who can do the job which isn't a bad thing.  Any comments much appreciated thanks for looking
Reply:Cant see the picture.
GMT+8, 2026-1-1 21:13 , Processed in 0.185713 second(s), 18 queries .
