Flame Thermal Spraying unit - Cast Iron Cylinder Heads R&D - In Melb Australia
发表于 2021-8-31 22:19:03 | 显示全部楼层 |阅读模式
Hi , I have used the search function on this fourm now for a while and read a lot of material on the subject and beautiful workmanship by some members on here. The run down I want to be able to weld cast iron cylinder heads for repair/porting R&D process when I cut through a port walls/roofs/floors . Don't want to use expoxy(s) or furnamce brazing methods. On some heads need to build up material in the port and outside surround areas when I have raise or widen the port Opening/Shape for more CSA.Would prefer to use Flame Thermal Spraying unit. Can not find a seller in Melbourne.Who In Melbourne Austraiai sells such equipment or other states of Australia ? Dont mention BOC or S/Gas would prefer to deal with direct seller(s)A unit similar to this "Flame Thermal Spraying unit Eutectic® SuperJet-S- System http://www.castolin.com/en-CA/produc...erjet-s-system would be great. Searched local yellowpages and just seem to come to a dead endGuys any assistance/advice would be appreciated.Cheers
Reply:I believe Messer acquired Castolin Eutectic. Here in the states I can get their stuff from Airgas/praxairLincolin Power Wave 450, Lincoln Powermig 255, Lincoln Pro Mig 140, Lincoln Squarewave Tig 275, Miller Big 40 G(with Hobart Hefty suitcase), Thermal Arc 95S and Esab PCM875 in an already full machine shop.
Reply:This is right off eutectic's web site in 2 min's. of time looking.There's  two other offices in OZ, as well, but I believe this isclosest to you.http://www.castolin.com/en-CA/about-castolin-eutectic-0Messer Eutectic AustraliaMarket Centre1300 728 422, 03 9466 40601300 728 [email protected] Longview Court3074 Thomastown, VIC- See more at: http://www.castolin.com/en-CA/about-....Xx4ZqLeD.dpufBlackbird
Reply:Hi propanehotrod & dave powelson , thanks guysCheers
GMT+8, 2026-1-1 21:12 , Processed in 0.074852 second(s), 18 queries .
