MIG gun recommendations
发表于 2021-8-31 22:19:02 | 显示全部楼层 |阅读模式
I finally committed on a MIG upgrade.  I found a pristine 2008 Millermatic 350P with a XR-AlumaPro air-cooled gun just under $3k.  I now need to find a steel gun...  I'm looking at the Bernard Q300 15 foot.  Any opinions, pros/cons?GlenMiller Dynasty 200DX - Millermatic 350P - Hypertherm Powermax 45Want to sell!! - Hobart Handler 150
Reply:Best gun for the money. I use the center fire consumables and would recommend them. The whip is a little stiff when new but after using it a while the stiffness goes away.
Reply:X3  Bernard CenterfireTiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
Reply:Can I come by and check out the cool new machine?
Reply:Originally Posted by MudmanCan I come by and check out the cool new machine?
Reply:Cool, look forward to seeing your work.
Reply:I love my Q300.  The consumables are available everywhere.  Love the Centerfire system as well, very easy to clean out spatter and the tips last a very long time.  My only gripe is that the nozzle is non-adjustable by design.  It seats the tip by being fully threaded on, so you need a different nozzle if you want to change the tip extension in relation to nozzle.  Mine came shipped with the nozzle that had the tip 1/8" recessed.  I cut the nozzle to allow me to have a 1/16 " tip extension as I usually do low amp SC mig.  The replacement nozzles with different stick outs can get pricey.  BTW, look on eBay for your Q300.  They are much cheaper than the MSRP.  You can usually get a good one for $100-125.TA Arcmaster 300CM3XMT 304S22P12 suitcase feederX-Treme 12VSOptima pulserTA161SMaxstar 150STLHypertherm PM45OP setupStihl 020AVP, 039, 066 Magnum
Reply:Well, the MM350P is here! Had to open it and switch to 230V, putting the 6-50P plug on the 8/4 wire takes a little work...  Now to acquire a gun... not setup to use the 25' XR-AlumaPro gun that came with it...Sent from my SM-G900V using TapatalkGlenMiller Dynasty 200DX - Millermatic 350P - Hypertherm Powermax 45Want to sell!! - Hobart Handler 150
Reply:Welcome to the 350 club!Tiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
Reply:Originally Posted by soutthpawWelcome to the 350 club!
Reply:Looks like I also need a new ground clamp.  This has the economy Lenco EC-300 and shows signs of getting hot! There is no copper in this clamp.I think I got a good deal, appears to only have 81.61 hours and 3875 arc startsSent from my SM-G900V using TapatalkLast edited by GlenC; 09-13-2014 at 12:31 AM.GlenMiller Dynasty 200DX - Millermatic 350P - Hypertherm Powermax 45Want to sell!! - Hobart Handler 150
GMT+8, 2026-1-1 23:12 , Processed in 0.067616 second(s), 18 queries .
