TIG Fuse by CK TIG Torches will fit standard TIG TORCH not DINSE
发表于 2021-8-31 22:18:59 | 显示全部楼层 |阅读模式
Have you ever had to replace the power cable on your torch?  Has it ever been because the water was either not turned on or because the water flow stopped?  Water-cooled power cables can burn up within seconds if water is not circulating through the cable assembly. This causes increased downtime and expense. A simple solution to this far too common problem is our Fuse Block Adapter. This device fits between the power cable and the power cable adapter. If water is not present over the fuse link, it will burn up at around 6 amps.A simple change of an inexpensive fuse link gets the welder back up and running. $50.00Used but good to go!Lincoln Power Mig 210MP MIGLincoln Power Mig 350MP - MIG and Push-PullLincoln TIG 300-300Lincoln Hobby-Weld 110v  Thanks JLAMESCK TIG TORCH, gas diffuser, pyrex cupThermal Dynamics Cutmaster 101My brain
Reply:I decided to keep this, but don't know how to delete the postLincoln Power Mig 210MP MIGLincoln Power Mig 350MP - MIG and Push-PullLincoln TIG 300-300Lincoln Hobby-Weld 110v  Thanks JLAMESCK TIG TORCH, gas diffuser, pyrex cupThermal Dynamics Cutmaster 101My brain
Reply:I need to pick up this for my set-up...sounds like a good insurance policy
GMT+8, 2026-1-1 19:22 , Processed in 0.099131 second(s), 18 queries .
