miller wirefeed with bobcat
发表于 2021-8-31 22:18:56 | 显示全部楼层 |阅读模式
I am thinking about getting a Bobcat 250 and a miller suitcase 8vs.  Has anyone had any experience with this?  Id like to be able to run fluxcore that is seismic rated for structural with this.  Just wondering if anyone has any suggestions.Thanks
Reply:i have a 250 and a 12vs. works good. takes some time to dial in. i founf running dual sheild wire works best for me
Reply:Originally Posted by grindel i found running dual sheild(sic) wire works best for me
Reply:Originally Posted by Joshfromsaltlake-->The whole idea of voltage sensing feeder was that they could be used with old constant-current stick welding supplies.  But pretty much all new power supplies have a CV option as standard equipment. That makes voltage sensing completely pointless, as waste of money.
Reply:I have the TB 302 which is a better choice for me doing mostly repair type work and has been said that the RC feeders are not worth the amount of money difference you pay and the 12RC hooks up to the 14 pin plug on my miller TB 302 so you don't have to run back to the welder to make adjustments and can be run in every mode of mig from short circuit to axel spray mode and do it quite well so i have been told by guys who have done itI have only run flux core in it so far and i only have used it for large fill jobs so farOh and guys just because you CAN put a 12 in reel of wire in it does not mean you have tooIf you don't want all that weight when climbing a ladder put a smaller reel of wire in itBacked my CATMA over your CARMA oops clusmy me  What would SATAN do ?? Miller Trailblazer 302 AirPakMiller Digital Elite  Optrel Welding HatArcair K4000Suitcase 12RC / 12 VSHypertherm PM-45Rage 3 sawRusty old Truck
Reply:I run a feeder off my TB301 and run hard and hot, usually ExcelArc 71 dual shield, or 5/64 NR-211 and the machine begs foe more. If I am gouging or running baseball bat 7024 the SA-250 makes an appearance.Disclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:DSW,Glad you countered JoshfromSaltLake's BS post.Maybe he'd like to suggest what feeder the OP should use on his Bobber since the Bobcat doesn't have the provision for remote control (which the TB does).This isn't the first post where he's chimed in with a BS response.  Seems to want to pull "bits and pieces" from other posts, but really doesn't understand the answer at all.Syncro 250 DX Dynasty 200 DXMM 251 w/30A SG XMT 304 w/714 Feeder & Optima PulserHH187Dialarc 250 AC/DCHypertherm PM 1250Smith, Harris, Victor O/ASmith and Thermco Gas MixersAccess to a full fab shop with CNC Plasma, Water Jet, etc.
GMT+8, 2026-1-1 19:22 , Processed in 0.077823 second(s), 18 queries .
