I need a weldable tapping fluid.
发表于 2021-8-31 22:18:55 | 显示全部楼层 |阅读模式
Hello,I have a fabrication shop in Mckinney Texas, and need to find a tapping fluid, that does not need to be washed prior to a welding operation.  We are using rapid tap now, and have to wash it off prior to welding.thank you for any guidance,Forrest
Reply:What about a stick lubricant like tap-ease? Less contamination... rapid tap gets everywhere.On my cnc lathe I run Cimstar 3890 which is semi-synthetic run at 5% to 10% with water. I know guys say that coolant makes for poor tapping but I'm running 316L stainless and I have over 200+ tapped holes with this tap. I've been impressed with the lubricity of the stuff and have been thinking of trying some in a spray bottle in place of rapid tap. Definitely cleans up easier.
GMT+8, 2026-1-1 21:11 , Processed in 0.098111 second(s), 18 queries .
