Lincoln diamond core?
发表于 2021-8-31 22:18:53 | 显示全部楼层 |阅读模式
I see Lincolns new machine's have something called diamond core it is ment to give better arc stability cans omeone explain what principal it works off and what the actual diamond core is?
Reply:Your best bet would be to check out Lincoln's web site for their explanation of what it is and what it does.A few of my toys !LinuxMintManjaroMiller Roughneck 2E Lincoln WeldPak 100HTP MTS 160 Chicago Electric 80amp Inverter   Victor O/A
Reply:The output choke has a diamond shaped air gap, to prevent saturation and to regulate the current/flux density.In theory the choke adjusts to improve weld quality from high to low amps.Does it work ?Don't know.
Reply:Of all their mig welders I got the only one with the Chopper Technology and not the Diamond Core. So I am of no use to you here. But I can say that the Chopper Technology works pretty darn well! Now, tell me why mine is the only one NOT using Diamond Core????Lincoln Power Mig 210MP MIGLincoln Power Mig 350MP - MIG and Push-PullLincoln TIG 300-300Lincoln Hobby-Weld 110v  Thanks JLAMESCK TIG TORCH, gas diffuser, pyrex cupThermal Dynamics Cutmaster 101My brain
GMT+8, 2026-1-1 19:22 , Processed in 0.073169 second(s), 18 queries .
