What's the most affordable 220v MIG Lincoln offers?
发表于 2021-8-31 22:18:52 | 显示全部楼层 |阅读模式
I was looking on the Lincoln Electric website, and a lot of their prices they list for retail seem really high.  Which model is their lowest priced 220v MIG?
Reply:I dont know to much about cost wise but durability I really like my 200,Thinking about getting the 225, no digital though. My 200 has been on the job everyday since 2001 and have only replaced the liner.1990 SA 200Miller 225  Rip Miller302Miller 135Lincoln 200 MigHypertherm 600 PlasmaPlasma Cam Cutting TableMikita Cold SawJL Welding Tx . com
Reply:I have a 180 hd from home depo,I really like it but I'm more of a hobby type welder.
Reply:Originally Posted by thefluxcorekidI was looking on the Lincoln Electric website, and a lot of their prices they list for retail seem really high.  Which model is their lowest priced 220v MIG?
Reply:thanks for all the info guys, i might trying looking for a clean used machine first.  i'm just getting tired of trying to squeeze every last amp out of my 110v mig.  I have a stick welder for heavy stuff, and I love using my little MIG on autobody sheet metal, but I'd like to be able to mig weld in between size material like 3/16" and 1/4" stuff.
Reply:This is somewhat of a common question. I don't want to sound like an a hole, but really, you can NOT go wrong by buying more than you need. Most certainly you will wish later that you had bought the bigger unit. You already know what it's like to have the 110v unit and want more. Imgaine the same scenario with the 180amp unit. If only I had 200amps....Anyways, to answer your question to the point, you will find that the model number ending in T will be a tapped output model. Those are usually cheaper than models ending with a C, which is Continuous adjustment. Both work great. I have had them both. The SP180T is the model you are looking for according to your question.Lincoln Power Mig 210MP MIGLincoln Power Mig 350MP - MIG and Push-PullLincoln TIG 300-300Lincoln Hobby-Weld 110v  Thanks JLAMESCK TIG TORCH, gas diffuser, pyrex cupThermal Dynamics Cutmaster 101My brain
Reply:I own a Powermig 180C, if you are wanting a unit to weld 1/4" with solid wire and shielding gas, you may want to consider looking at the Millermatic 180 or Hobart Handler 187 instead. The reason being, because with solid wire and shielding gas, the 180 amp Lincoln doesn't offer as much top end power as the Miller or Hobart units.  Set up with .023 and C-25, and dialed in correctly, the PM180C produces a very good ( very soft) low end arc for thin ga auto sheet metal.ESAB Migmaster 250 Hobart Ironman 230Multimatic 215TWECO Fabricator 181i & 211iHH125EZ - nice little fluxcore only unitMaxstar 150 STH - very nice
Reply:Originally Posted by JLWeldingI dont know to much about cost wise but durability I really like my 200,Thinking about getting the 225, no digital though. My 200 has been on the job everyday since 2001 and have only replaced the liner.
Reply:Originally Posted by Canadian WeldorLincoln has a 200amp. Mig ?? Which one is that ?
GMT+8, 2026-1-1 21:13 , Processed in 0.095121 second(s), 18 queries .
