What motor is in my 1986 Lincoln sa 250
发表于 2021-8-31 22:18:50 | 显示全部楼层 |阅读模式
What motor is in my 1986 Lincoln sa 250 its a 4 cyl flat head gas welder
Reply:Probably a continental 163 but pictures would be nice.FelonCaution lurker lives here" hmmm That is serious,pass the ganja and pick up a  24 of MGD"
Reply:ok that what I thought my fireing order is stamped on my head 1-3-4-2 now is number 1 at the fan or the genetator because it runs the same either way
Reply:First, if you're going to own a Lincoln welder and work on it then go here http://www.mylincolnelectric.com/Cat...ualsearch.aspx and get the correct Operator's Manual based on your units Code number. Then go here and click on "Engine Driven Welders", scroll down and click "Adjustment instructions" or scroll further to "Pipeliner info", there should be what your looking for there too...Good luck!Only when the last tree has died and the last river has been poisoned and the last fish has been caught will we realize we cannot eat money.                                         -Cree Indian ProverbSA 200 LincolnVictor Torches
Reply:. . . then go here http://www.weldmart.com/default.htm and request your free CD loaded with tons of informatiom every SA200 owner should have.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
GMT+8, 2026-1-1 23:13 , Processed in 0.073651 second(s), 18 queries .
