ON some of the lincoln models, they are are both 110v and 230v capable. does anymore mak a nice, clean adapter plug for doing this?I don't want to make some ugle home depot adapter using a junction box.Something liek the Miller MVP would be great....hmmmm.....I wonder if miller sells the parts for the MVP (multi voltage plug.)
Reply:No one makes one.It is up to you to make it all purdyEd Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:i suppose so.....this is a welding/fab forum........If you can't buy it, make it!
Reply:Originally Posted by BurningMetalON some of the lincoln models, they are are both 110v and 230v capable. does anymore mak a nice, clean adapter plug for doing this?I don't want to make some ugle home depot adapter using a junction box.Something liek the Miller MVP would be great....hmmmm.....I wonder if miller sells the parts for the MVP (multi voltage plug.)
Reply:Rhyno,Can you post a picture of the plug? That'd be great!
Reply:Originally Posted by BurningMetalRhyno,Can you post a picture of the plug? That'd be great!
Reply:you can easily make your own , just remember to put an appropiate breaker between the 220 and 110. |
