查看: 13|回复: 0
Day bed frame completed
发表于 2021-8-31 22:18:48 | 显示全部楼层 |阅读模式
The old guy needed a bed for when he wanted to be in the family room so I built one..Here you go..All square tubing and got some use of the JD2 bender.. Miller 140 mig welder and some grinding cutting and sanding for paint. A twin size mattress fits this bed and it is real comfy for watching the game..Sam
Reply:Is that because he wants to be in the family room or has to be!!
Reply:No no no. You have it backwards. You use bed frames to weld things, not weld up bed frames. .No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:Nice work.DSW, I think he used the bed frame for another project so he had to use square tubing to build the bed. GravelThe difference between theory and practice is that in theory there is no difference.
Reply:It came out nice even if we are not clear on the reason he had to sleep in the family room
Reply:Originally Posted by DSWNo no no. You have it backwards. You use bed frames to weld things, not weld up bed frames.
Reply:Looks great,  btw.Regards,RobGreat Basin WeldingInstagramBlue weldersRed weldersMy luscious Table DIY TIG Torch cooler
Reply:Very niceMillerMatic 252, HTP 221 w/cooler, Hypertherm PM45, Lincoln IdealArc 250 AC/DC"I'd like to believe as many true things and as few false things as possible"
GMT+8, 2026-1-1 22:56 , Processed in 0.158021 second(s), 18 queries .
