Millermatic w/ SKP-35 -- Good Deal Used? Spool Gun that Fits?
发表于 2021-8-31 22:18:40 | 显示全部楼层 |阅读模式
Found a local Millermatic with SKP-35 all working, seller asking $495. Does not have a bottle. Few questions: What Spoolgun to weld aluminum will this accept? Can the guns be found or does a new gun have to modded to work? Is $495 high? I thought I'd offer $300 considering the age, it's mid 80s right? Thanks
Reply:I paid 400 for one of the MM 200s I have had.If you don't find a Spoolmatic 1 you should be able to get a conversion cable, WC24 weld controller and a 15/30A spool gun.Like 7A says......snap it up if it welds!
GMT+8, 2026-1-1 21:13 , Processed in 0.214325 second(s), 18 queries .
